T3chTr3kk3r
Jun 06, 2022Guide
Configuration issue detected - device security at risk
My wife & I both have the same brand of Android phones, and I've set up both of us with Armor Security, Bitdefender, etc. My wife's phone is the only one that gets this "Configuration issue detected"...
T3chTr3kk3r
Jul 21, 2023Guide
Since I can't find a way to update my own post, I'll reply to my own post.
Nope, the actions I described in my earlier post here ... which seemed to have worked for the folks who'd posted about it ... did NOT truly "fix" the problem. Also, my Chromebook doesn't even have the option to change battery settings, as far as I've been able to determine. This same problem notification still crops up now and again, with the result of my treating this as "the little boy who cried wolf" ... and leaves me concerned I'm missing some important issue, or that I will miss something important.
I'm starting to question whether it's worth paying for this Netgear software.
canah23
Aug 18, 2023Aspirant
I have a config issue on my computer now cus i did a clean wipe with windows, so i'm deleting every device off of armor, then i hear you can forget the network and put everyone back on your network (allow access, i assume everyone uses at this point, i was the last to know lol!)... and it can possibly work better, but i'm still wondering about all of our raondomized mac's wouldn't that effect it since it grabs the mac id and not the device? BTW on email and phone with them for weeks about armor... no one has an answer to that question at all...
- canah23Sep 14, 2023Aspirant
So responding to myself, got a new phone and theres a config error everyday and HAS ANYONE gotten Armor to work on their app? Because I'm still in the dark, just saying i'm protected by armor but that i need an activation code... not possible... don't have one... the app worked perfect for one night. MAYBE because of the config errors on both devices that I have contacted you about, you can work on getting my app up and running since i performed all of the IT work your "pro" support would have. People that buy expensive products are usually not as stupid as you'd assume when it comes to tech. ESP not me and the other person who we are both speaking to ourselves!!!!
