T3chTr3kk3r
Jun 06, 2022Guide
Configuration issue detected - device security at risk
My wife & I both have the same brand of Android phones, and I've set up both of us with Armor Security, Bitdefender, etc. My wife's phone is the only one that gets this "Configuration issue detected"...
T3chTr3kk3r
Jul 21, 2023Guide
Since I can't find a way to update my own post, I'll reply to my own post.
Nope, the actions I described in my earlier post here ... which seemed to have worked for the folks who'd posted about it ... did NOT truly "fix" the problem. Also, my Chromebook doesn't even have the option to change battery settings, as far as I've been able to determine. This same problem notification still crops up now and again, with the result of my treating this as "the little boy who cried wolf" ... and leaves me concerned I'm missing some important issue, or that I will miss something important.
I'm starting to question whether it's worth paying for this Netgear software.
canah23
Aug 18, 2023Aspirant
there is no answer, they can't even answer it, they can't answer any of my questions and i have paid now for every service they offer... if they use bitdefender, why not go straight to them? If youre not worried about router security (which is ARMOR AND BITDEFENDER for the rest of the devices) go with bitdefender for mobile and comp. they don't support your nighthawk, orbi, etc...
