Vxzal
Mar 05, 2025Aspirant
RS300 not sending the correct speeds but is pulling the correct from the modem,
I just recently moved to a new house where I'm able to get Spectrum internet. I matched up their provided Modem with the Netgear NightHawk RS300 for the 1gb speeds. When I test my internet speeds on ...
Vxzal
I had two of my buddies that understand a little more than me in this regard check my PC and they both said I shouldn’t have a problem getting the 1gb down. I have a 2070 Super, Ryzen 7 3700x, and an x570 plus WiFi ASUS TUF Gaming motherboard.
Mar 05, 2025Guru - Experienced User
I've seen a few posts lately with RS users experiencing decreased speeds.
Try a factory reset. during the reinstall, only change your ssid/internet settings needed to get it working. Test it from that point.
