libremente
May 29, 2020Follower
Deactivate ARMOR trial completely from ORBI APP
May 28, 2020: Here is what works 1. Upper left corner of iPhone press home symbol in circle on ORBI APP 2. Menu opens, select security 3. Slide Netgear Armor Enable slider to disable position. 4....
May 31, 2020Guru - Experienced User
Please post about this in the Armor app forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
libremente wrote:May 28, 2020: Here is what works
4. Back to main menu select setup router and click reboot at bottom of page
5. After you've lost internet and everything, remove power from ORBI and your modem.
6. Reconnect modem power, and ORBI power
7. Everything should come back up with internet enabled and ARMOR inactive.
Good luck. Nothing seems to work as it could with Netgear. You have to figure it out.
