Joziefiend
Apr 02, 2019Follower
Deactivating Amor trial
How do you deactivate the Amor security trial?
beotto
Apr 03, 2019Guide
hi
I have an orbi rbk50 and after activated armor my network is not working fine.
all my google devices are not working, my meros light buld does not connect any more.
anyone experiencing the same ?
is there any fix, i disable armor but it still shows as activated.
any help is appreciated, the house stoped !!!
regards,
bruno
BigScotty
Apr 06, 2019Initiate
Had similar problems with massive outage across devices since activating Armor yesterday. Even these community forum pages had difficulty loading or were stopped - and that was through my wired pc, not wifi. Prior ro enacting Armor the router had been awesome.
I have since disabled Armor in the app (Settings - security), restarted the router and it appears to be better.
Have lodged ticket to understand what issues are, as there is a real lack of info from searches. For now, until Support clarify what is going on, I cannot see any way this Armor add on is usable.
- beottoApr 06, 2019Guide
HI
I ve done the same and i think now things are getting better.
what i realised is that somehow my modem could not send data (upload = 0)
i tryed to reset it with the orbi attached, no good, only works when i unpluged orbi from the modem.
i dont know if that makes sense, but is a fact, worked.
thanks all
regards
bruno
- BruizerApr 20, 2019Initiate
How, exactly, were you able to disable it? There is nothing in my app that I can find to disable it. It is really a piece of junk and blockign all manner of legitimate website.
Thanks!!
- BigScottyApr 20, 2019Initiate
I used the Nighthawk app on my mobile. From the opening screen selected security (or go via Home icon top left, Settings, Security) and the first option is an on/off button to Enable NETGEAR Armor. I just turned this to off and no more problems until such time it is clarified the issues are resolved.
