Joziefiend
Apr 02, 2019Follower
Deactivating Amor trial
How do you deactivate the Amor security trial?
geoffcullen
Apr 23, 2019Tutor
This may be no use to you now, but here's how I did it... in the Orbi app on my iPhone I selected Settings from the mqin Menu... then I opened the Security section, In here is a slider switch called Enable Netgear Armor... slide it to the Off position. That seems to do it. I had to disable Armor because it was messing up my internet connection and totally screwed with my Apple TVs. Armor seems to be a nice idea but it doesn't seem ready for prime time yet... very disappointing as of now.
NicevilleSteve
Jul 05, 2019Tutor
Your solution worked perfectly! :smileyhappy:
