Nitrorig
Mar 02, 2024Aspirant
Deeper VPN and browser issues
Has anyone every used a "deeper network vpn" decentralised vpn with their Orbis router... My router works fine until i connect the DPN box and browsers stop working and i can't run IPTV through my m...
Mar 13, 2024Guru - Experienced User
Something to contact the VPN Mfr about regarding there product for help and support there.
- NitrorigMar 13, 2024AspirantI have but they have said as it worked perfectly before on the old router and all you have done is change the router then it must be the new router that needs new settings. If I take the vpn out everything works normal. I’m bouncing between the 2 and not getting anywhere.
