Beus's avatar
Beus
Tutor
Jul 20, 2022
Denial of Service from IP to Local PC, which is the same (RAX70)
Hello, Since today I get alot of notifications that my local PC (which has Bitdefender Total Security installed) is involved in an DoS attack: "NETGEAR Armor blocked a Denial of Service attack invo...
  • Beus's avatar
    Aug 09, 2022
    The solution is to disable "Port scan protection". In my case in Bitdefender. But I guess it could also happen in any other security software solution.
