Beus
Jul 20, 2022Tutor
Denial of Service from IP to Local PC, which is the same (RAX70)
Hello, Since today I get alot of notifications that my local PC (which has Bitdefender Total Security installed) is involved in an DoS attack: "NETGEAR Armor blocked a Denial of Service attack invo...
- Aug 09, 2022
The solution is to disable "Port scan protection". In my case in Bitdefender. But I guess it could also happen in any other security software solution.
MickMorrison
Aug 06, 2022Aspirant
I'm having the same problem with my XR1000, also since installed the BitDefender and shows no vulnerability. Haven't tried hooking up the laptop to see if it has the same issue, no other device causes it.
No loss of connectivity, but over 100 blocked DoS from my PC. I'm an IT tech and keep my system secure, so unlikely a real threat.
But an actual answer from a Netgear rep would be nice.
Beus
Aug 06, 2022Tutor
Thanks for your reply.
I am also an IT tech guy, and I found out that this happens when your Netgear Armor performs an port scan on your devices in the network.
And I also found out that it is Bitdefender (BD) on the PC that blocks the router IP.
So first I tried to whitelist the router in BD in the firewall settings, wel that did not work. After that I found under the firewall settings an "Port scan protection" option. I have disabled that now.
I have the feeling that that is the protection from your PC that blocks your router, since the Netgear Armor is performing an port scan.
And I also don't feel like you compromise the protection of your PC since you still have the Netgear Armor in your network between your ISP and PC.
And yes this forum is dead, very sad. Guess we have to look for another community for help in the future if the need arises.
