CRiddell
Jun 04, 2019Tutor
Disable Ads in Orbi App?
I keep getting ads in my notification tray from the Orbi app trying to get me to turn on Armor. The only setting I can find to turn off the advertising is to disable all notifications and I'd rat...
Orbi-Roc
Jun 15, 2019Luminary
Which Orbi app are you using (i.e. which platform are you on)?
CRiddell
Jun 25, 2019Tutor
I posted a reply a week ago and it never appeared. Maybe it was flagged as spam?
Anyway, the app is on my Pixel 2 phone running Android (fully patched) and the Orbi app is version 2.3.6.617.
