Louiem
Apr 29, 2020Aspirant
Disable Armor - Causes printer time print
Somehow I accidentally tuned on this Armor. It now causes my printer to print showing port 9100 open. I tried click disable in app, the slider shows off but app says Activated still. Firmware is 2.3....
Apr 29, 2020Guru - Experienced User
The OP mentioned that they used the app to disable Armor and the printer was still getting print problems. So a reset should fix this. Even after a FW update.
CrimpOn
FURRYe38 wrote:The OP mentioned that they used the app to disable Armor and the printer was still getting print problems. So a reset should fix this. Even after a FW update.
Sorry, I missed that. "My Bad" An interesting finding that despite being deactivated, Armor continues to run? Hmmm.
