ggarris1
Mar 14, 2024Aspirant
Disable Armor on singular device
How do I disable armor on a singular device and not affecting other devices in network? I want protection on all devices except one that needs freedom to go anywhere without restrictions. Operating w...
ggarris1
Mar 21, 2024Aspirant
My whole home network for my trip-band router is controlled by Nighthawk and uses Armor. I only see where you select Armor ON for complete network or OFF.
Thanks
Apr 25, 2024Guru - Experienced User
You can only enable or disable Armor from the mobile app that covers the entire network.
