kwterp
Feb 02, 2021Follower
Disable Armour auto renewal
How do you turn off Armour auto renewal
- Jul 26, 2021
Looks like cancelling auto-renew should be an easy fix. I just paid for a year and had the same pingeonholing hatred going on. Hopefully the pics come thru. But the steps are simple.
1. Tap settings/home icon at top left of nighthawk app
2. Select "Add Ons"
3. Select "Security"
4 Toggle off "Auto-Renew"
I'm still under the "Trial" version so app's telling me I can't toggle off till actual paid subscription kicks in. I do hope it's as easy as that.
Be well
Christian_R
Feb 05, 2021NETGEAR Employee Retired
Hi kwterp,
You may view your subscription by tapping on the security tile and then to settings. You should be able to edit your susbcription.
Christian
- Pama31Jun 10, 2021InitiateTo be clear, this particular answer doesn't work, at least not on the latest iOS app.
