kwterp's avatar
kwterp
Follower
Feb 02, 2021
Disable Armour auto renewal
How do you turn off Armour auto renewal
  • MrWibbles's avatar
    Jul 26, 2021
    Looks like cancelling auto-renew should be an easy fix. I just paid for a year and had the same pingeonholing hatred going on. Hopefully the pics come thru. But the steps are simple.
    1. Tap settings/home icon at top left of nighthawk app
    2. Select "Add Ons"
    3. Select "Security"
    4 Toggle off "Auto-Renew"
    I'm still under the "Trial" version so app's telling me I can't toggle off till actual paid subscription kicks in. I do hope it's as easy as that.
    Be well
