kwterp
Feb 02, 2021Follower
Disable Armour auto renewal
How do you turn off Armour auto renewal
- Jul 26, 2021
Looks like cancelling auto-renew should be an easy fix. I just paid for a year and had the same pingeonholing hatred going on. Hopefully the pics come thru. But the steps are simple.
1. Tap settings/home icon at top left of nighthawk app
2. Select "Add Ons"
3. Select "Security"
4 Toggle off "Auto-Renew"
I'm still under the "Trial" version so app's telling me I can't toggle off till actual paid subscription kicks in. I do hope it's as easy as that.
Be well
shani456
Jul 30, 2021Aspirant
Hey, can you mention what are the Errors you are facing in renewal, then i'll be able to share views on it. You can check helpful site for more information,
- MrWibblesJul 30, 2021Guide
shani456 ,
Thank you for the response. It's not so much Errors, which I suppose could depend on perspective. It's more so on how to cancel Armor's autorenewal from continuing in perpetuity. I'm always cautious and/or decline to enter into agreements where "autorenewal" is a term in the contract. Above, others were like minded so I thought I'd share what looks to be the process to cancel Armor's automatic renewal. I may keep it after a year or I may not, but I need to have control of how that goes. Ya dig? Keep your head up!
