Trebron
Jan 11, 2020Aspirant
Disable Bit Defender - Nighthawk R7000
how do I disable Netgear armour bit defender the software only shows me the pourchase page through oirbi app but I don`t want to purchase it I want to disable it I have read on here about connection ...
- Jan 23, 2020
It seems to have settled down now all good until the next issue
DexterJB
Jan 15, 2020NETGEAR Moderator
Hi Trebron, welcome to the community! You can check the link below for the steps on how to disable the Armor feature.
If the trial has expired, then the feature is automatically disabled.
May we know the firmware version of your R7000?
Dexter
DexterJB
Jan 19, 2020NETGEAR Moderator
