nishgabas
Dec 06, 2022Follower
Disable or remove Bitdefender
Armor Bitdefender is driving me crazy. Netgear doesn't support the software. You have to talk to Armor Bitdefender Support (Chinese, no understand English). Totally frustrated. There seems to be no...
Wxman38
Dec 06, 2022Guide
That doesn't really disable it.
Dec 06, 2022Guru - Experienced User
The basics of it are built into the firmware. You can't fully remove it. All you can do is disable it.
If you think its still running, try a factory reset.
- Wxman38Dec 06, 2022Guide
Does a factory reset actually take you back to a point that it doesn't exist?
- plemansDec 06, 2022Guru - Experienced User
What device do you have it on?
Like I said, its baked into the firmware. the only way to get rid of it entirely would be to downgrade to a version prior to armor (if there is one) or to switch to a 3rd party firmware.
