RVx1
Dec 06, 2023Apprentice
Enable Protection Engine option
 Hi ,  Can someone explain what is the "Protection Engine" that i found in web management of my RAX50 Router ?  It seems not related with Armor.  Connect with cable and with this option enabled the pi...
RVx1
Hi ,
yes , i have the V1 Version .
The firmware is V1.0.16.132_2.0.92 and came from automatic update some days ago
 I dont't know if this option came in the last FW update or was already there. The default seems to be ON
From my testing is not related with Armor . I have a valid Armor subscription and with that flag on or off does not seems to change anything in Armor
The only evidence is that the ping is much higher if the flag is on
Switching on/off the router apply immediatly wiout reboot or waiting but suddenly the ping time change
Dec 06, 2023Guru - Experienced User
Seems that Armor differs from Bit Defender.
Someone told me from there review of this, seems to be Bit Defender related however haven't got official word from NG yet. Information shows more memory usage when it's enabled vs not enabled. So something is using more memory when it's enabled.
Doe ping time change for the better or worse when it's enabled and disabled?
Seems like NG is pushing FW to a small group as a test. I wish they would use other resources first before going out to the public. đꤔ
Try both enabled and disabled for this feature and post your experiences. If something comes up or you find a problem post here and let us know.
- RVx1Dec 06, 2023ApprenticeHi , Until now only evicence is ping time and after the last switch off to on the router crash and i had to restart it Here below the ping time all with ethernet cable FLAG DISABLED C:\Users\rober>ping 192.168.10.1 -t -n 5 Esecuzione di Ping 192.168.10.1 con 32 byte di dati:
 Risposta da 192.168.10.1: byte=32 durata=1ms TTL=64
 Risposta da 192.168.10.1: byte=32 durata=1ms TTL=64Statistiche Ping per 192.168.10.1:
 Pacchetti: Trasmessi = 5, Ricevuti = 5,
 Persi = 0 (0% persi),
 Tempo approssimativo percorsi andata/ritorno in millisecondi:
 Minimo = 1ms, Massimo = 1ms, Medio = 1msFLAG ENABLED ( default ) C:\Users\rober>ping 192.168.10.1 -t -n 5 Esecuzione di Ping 192.168.10.1 con 32 byte di dati:
 Risposta da 192.168.10.1: byte=32 durata=6ms TTL=64
 Risposta da 192.168.10.1: byte=32 durata=4ms TTL=64
 Risposta da 192.168.10.1: byte=32 durata=4ms TTL=64Statistiche Ping per 192.168.10.1:
 Minimo = 4ms, Massimo = 6ms, Medio = 4msC:\Users\rober> - FURRYe38Dec 06, 2023Guru - Experienced UserThank you for the comparison. Ya, seems like it's effecting things when it's enabled. - TopologyDec 12, 2023VirtuosoInterestingly, the Protection Engine option does not appear to be available for the RAXE500 with the 1.2.13.100 firmware (see Settings | Advanced | Security).
