cavernap
Jun 08, 2020Aspirant
extending Netgear Armor subscription
I bought an Orbi RBR50 a year ago and it came with a year of Netgear Armor. Last month I got notifications that the Netgear Armor was going to expire, so I bought a year subscription through the link...
- Jun 10, 2020
Hi cavernap,
While on the security page in the app, do you see 3 vertical dots at the top right hand corner. If so, that should be the menu icon where you can select your subscriptions and enter an activation code. You may also try visiting armor.netgear.com through a web browser and entering your activation code there.
Christian
Christian_R
Jun 08, 2020NETGEAR Employee Retired
Hello cavernap,
Welcome to the community! In the confirmation email, there should be steps included to activate your subscription using the activation code. If not, no need to worry! Here's an article on how to activate Armor using the code you received.
Let me know if you have any further questions!
Christian
- cavernapJun 10, 2020Aspirant
Hi Christian,
Thank you for sending me the link on how to activate. (I bought the year subscription through the link that was provided (turns out it is a third party vendor, 2CO) but they didn't send me the confirmation code or the instructions. I managed to find the code, but not the link.) But I am having problems following the instructions. When I open the Orbi app (on my android phone), the security tile says that Armor is expired. When I tap on the tile, it sends me to the Bitdefender website to buy a subscription. After pressing several other buttons (back button, etc), I managed to get to the security page in the app, but I don't see an Armor page or a menu option. I have a screenshot of the app on my phone. Where do I go from here?
- Christian_RJun 10, 2020NETGEAR Employee Retired
Hi cavernap,
Christian
Hi Christian,
I was able to log in on the webpage and enter my activation code. Then I went back to the Orbi app on my phone. The security tile now says 'activated', but there still is no menu option or three dots in the corner. I found this entire process very confusing and frustrating. And I still don't know how Netgear, Orbi, and Armor are related. It seems like I have signed into multiple websites, all with different passwords.
