cavernap
Jun 08, 2020Aspirant
extending Netgear Armor subscription
I bought an Orbi RBR50 a year ago and it came with a year of Netgear Armor. Last month I got notifications that the Netgear Armor was going to expire, so I bought a year subscription through the link...
- Jun 10, 2020
Hi cavernap,
While on the security page in the app, do you see 3 vertical dots at the top right hand corner. If so, that should be the menu icon where you can select your subscriptions and enter an activation code. You may also try visiting armor.netgear.com through a web browser and entering your activation code there.
Christian
cavernap
Jun 10, 2020Aspirant
Hi Christian,
Thank you for sending me the link on how to activate. (I bought the year subscription through the link that was provided (turns out it is a third party vendor, 2CO) but they didn't send me the confirmation code or the instructions. I managed to find the code, but not the link.) But I am having problems following the instructions. When I open the Orbi app (on my android phone), the security tile says that Armor is expired. When I tap on the tile, it sends me to the Bitdefender website to buy a subscription. After pressing several other buttons (back button, etc), I managed to get to the security page in the app, but I don't see an Armor page or a menu option. I have a screenshot of the app on my phone. Where do I go from here?
Christian_R
Jun 10, 2020NETGEAR Employee Retired
Hi cavernap,
Christian
- cavernapJun 10, 2020Aspirant
Hi Christian,
I was able to log in on the webpage and enter my activation code. Then I went back to the Orbi app on my phone. The security tile now says 'activated', but there still is no menu option or three dots in the corner. I found this entire process very confusing and frustrating. And I still don't know how Netgear, Orbi, and Armor are related. It seems like I have signed into multiple websites, all with different passwords.
- CharlieBrienJul 09, 2020Tutor
I'm having a similar problem with my Orbi. I just renewed my Armor subscription and entered the provided activation code. Now the subscription shows *active* (359 days remaining) on armor.netgear.com but under router security it shows '0 devices'. The iPhone Orbi app shows Armor as expired. I had trouble when I signed up last year so renewal is quite frustrating. Can anyone assist or point me to someone who can help? TIA.
- Christian_RJul 14, 2020NETGEAR Employee Retired
Hi CharlieBrien,
May you reboot your router and reinstall the Orbi app. Please let me know how this turns out.
Christian- CharlieBrienJul 14, 2020Tutor
Christian,
I will try that but as I'm working from home that must be done after business hours. I had this exact same problem 1 year ago when I purchased a subscription after the 2 week trail period elapsed. Same symptoms... in the Amor subscription details, 'router security' showed 'devices: 0' and the app showed expired. Same as now. I posted that issue on this board and someone corrected it (been looking frantically for who that was). No reboot required. I'm feel like the same situation exists now. If I recall correctly there was a sync problem between Netgear and Bitdefender but without finding the reply, I cannot confirm. I will try the router restart tonight.
Thanks,
Charlie
