cavernap
Jun 08, 2020Aspirant
extending Netgear Armor subscription
I bought an Orbi RBR50 a year ago and it came with a year of Netgear Armor. Last month I got notifications that the Netgear Armor was going to expire, so I bought a year subscription through the link...
- Jun 10, 2020
Hi cavernap,
While on the security page in the app, do you see 3 vertical dots at the top right hand corner. If so, that should be the menu icon where you can select your subscriptions and enter an activation code. You may also try visiting armor.netgear.com through a web browser and entering your activation code there.
Christian
Christian_R
Jun 10, 2020NETGEAR Employee Retired
Hi cavernap,
Christian
CharlieBrien
Jul 09, 2020Tutor
I'm having a similar problem with my Orbi. I just renewed my Armor subscription and entered the provided activation code. Now the subscription shows *active* (359 days remaining) on armor.netgear.com but under router security it shows '0 devices'. The iPhone Orbi app shows Armor as expired. I had trouble when I signed up last year so renewal is quite frustrating. Can anyone assist or point me to someone who can help? TIA.
- Christian_RJul 14, 2020NETGEAR Employee Retired
Hi CharlieBrien,
May you reboot your router and reinstall the Orbi app. Please let me know how this turns out.
Christian- CharlieBrienJul 14, 2020Tutor
Christian,
I will try that but as I'm working from home that must be done after business hours. I had this exact same problem 1 year ago when I purchased a subscription after the 2 week trail period elapsed. Same symptoms... in the Amor subscription details, 'router security' showed 'devices: 0' and the app showed expired. Same as now. I posted that issue on this board and someone corrected it (been looking frantically for who that was). No reboot required. I'm feel like the same situation exists now. If I recall correctly there was a sync problem between Netgear and Bitdefender but without finding the reply, I cannot confirm. I will try the router restart tonight.
Thanks,
Charlie
Hi Charlie,
Sounds good! Please let me know how it turns out.
Christian
