cavernap
Jun 08, 2020Aspirant
extending Netgear Armor subscription
I bought an Orbi RBR50 a year ago and it came with a year of Netgear Armor. Last month I got notifications that the Netgear Armor was going to expire, so I bought a year subscription through the link...
- Jun 10, 2020
Hi cavernap,
While on the security page in the app, do you see 3 vertical dots at the top right hand corner. If so, that should be the menu icon where you can select your subscriptions and enter an activation code. You may also try visiting armor.netgear.com through a web browser and entering your activation code there.
Christian
Christian_R
Jul 14, 2020NETGEAR Employee Retired
Hi Charlie,
Sounds good! Please let me know how it turns out.
Christian
CharlieBrien
Jul 15, 2020Tutor
Christian,
Bitdefender support resolved the issue. I did not have a chance to reboot last night. I noticed this morning my Armor subscription showed Active. Appreciate you responding to my post.
Thanks again,
Charlie Brien
- Christian_RJul 17, 2020NETGEAR Employee Retired
Hi Charlie,
Thanks for getting back with an update. Happy to hear you're up and running!Best,
Christian
