johnw1ck
Mar 11, 2022Tutor
Forced Netgear Armor trial.
Latest Nighthawk update forces the end user to agree to a 30-day free Netgear Armor trial in order to activate and keep using the app. I do not want a free trial, I do not want Armor. I do not want t...
Mar 11, 2022Guru - Experienced User
I've not gotten the forced install option on mine. But I did install using the browser and declined the armor trial through the browser.
did you try that?
- johnw1ckMar 12, 2022Tutor
In order to activate and use the Nighthawk app. after the latest app update, you have to agree to the Armor install or you can't activate and use it. So, unless you want to sign-in via browser for everything, you have to install Armor to use the app.
- plemansMar 12, 2022Guru - Experienced User
the actual armor is built into the firmware. You can enable it to get it activated and then just de-activate it.
I dont want to enable it or want it at all. I just want to be able to use the app to control my router, like I have been for years, and not forced into a 30-day trial in order to even open the app. It's BS.
- michaelkenwardApr 25, 2022Guru - Experienced User
I have noticed this pop-up in the Android app, but I was not forced to accept anything to progress.
- michaelkenwardMar 15, 2022Guru - Experienced User
How do you install an app using the browser?
I have to do it on the device itself.
