johnw1ck
Mar 11, 2022Tutor
Forced Netgear Armor trial.
Latest Nighthawk update forces the end user to agree to a 30-day free Netgear Armor trial in order to activate and keep using the app. I do not want a free trial, I do not want Armor. I do not want t...
johnw1ck
Apr 01, 2022Tutor
Topology I appreciate your response, but it has nothing to do with my issue nor the topic of this thread. I've tried to make this as clear as possible numerous times. My issue is that I want to use the IOS app to control my router, in order to do that I have to agree to a FORCED armor trial in order to just use the app, which I do not want nor will ever want. I do not want to be forced into a Armor "30-day" trial in order to use the app. Which of course automatically rolls into subscription after the 30-days. It's one of the scummiest moves I've seen. Even if it didn't roll into a subscription, I DO NOT WANT ARMOR! I never once mentioned the analytic issue, so I don't want this thread dissolving into that issue.
Donnamw
Apr 02, 2022Tutor
Did you get your app working without being forced into armour trail? My app on my iPhone is doing the same thing.
- StuntPandaApr 24, 2022Aspirant
Anyone else getting this forced installation of the Netgear Armor trial? Not only can you not avoid the installation but you also have to agree to terms and conditions you don't agree with. All just so you're allowed to access your Orbi system!
Forced Acceptance is Not Acceptance
- cuivreApr 25, 2022InitiateSame thing just started happening to me on the Orbi app.
