johnw1ck
Mar 11, 2022Tutor
Forced Netgear Armor trial.
Latest Nighthawk update forces the end user to agree to a 30-day free Netgear Armor trial in order to activate and keep using the app. I do not want a free trial, I do not want Armor. I do not want t...
johnw1ck
Mar 12, 2022Tutor
In order to activate and use the Nighthawk app. after the latest app update, you have to agree to the Armor install or you can't activate and use it. So, unless you want to sign-in via browser for everything, you have to install Armor to use the app.
michaelkenward
Apr 25, 2022Guru - Experienced User
I have noticed this pop-up in the Android app, but I was not forced to accept anything to progress.
