Whistler73
Nov 29, 2022Initiate
Horrible customer service, tech support has no clue, left me high and dry!
I had written a very articulate summary of my experience but apparently that was not meant to be so, this time I will be more concise (you're welcome đ 1) New R6700AX router. 2) Installed no p...
Nov 30, 2022Guru - Experienced User
DNS is not user configurable if Armor is enabled. Armor uses it's own DNS serivces.
- Whistler73Nov 30, 2022Initiate
Well now...that makes sense!!! Thank you sir for a quick and technically feasible answer! In other words, the replacement router they sent me will not do anything differently (which I told them on the tech support call) and the disablement of my AV subscription pending receipt of the new router is therefore completely unnecessary.
Again...thank you for the meaningful response! Do you by chance know what DNS is being used with Armor activated?
- FURRYe38Nov 30, 2022Guru - Experienced User
I don't. I don't use Armor much.
Might do a search on line to see if there is any information regarding this.
