goddss6
May 28, 2019Follower
How do I disable/delete Netgear Armour
I accepted the trial of Netgear Armour and have been trying for a month to turn this crap off. I do not want it. It says that I have 45 days left... My phone dings that there is security threat eve...
Orbi-Roc
Jan 30, 2020Luminary
Hi Tunnu . If you properly disabled Armor from your mobile device, then it shouldn't be intefering with anything. If you go to your router Web page, and navigate to [Advanced Tab]
[Advanced Setup] [Wireless Settings], see if Daisy-Chain-Topology is enabled under the Backhaul Toplogy section. This should be enabled ONLY if you have more than one satellite paired to your router. If you only have one satellite, please remove the checkmark to disable it and reboot your router. Hope this works. Have a good one.
