goddss6
May 28, 2019Follower
How do I disable/delete Netgear Armour
I accepted the trial of Netgear Armour and have been trying for a month to turn this crap off. I do not want it. It says that I have 45 days left... My phone dings that there is security threat eve...
DexterJB
Nov 26, 2019NETGEAR Moderator
Hi CoGizmo, we'd like to help out. To confirm, you're experiencing slow Internet speeds when Armor is enabled, correct? If so, does disabling Armor get your speeds back to how they should be? You can check the link below for the steps on how to disable Armor.
Dexter
ChrisSpeakman
Jan 05, 2021Aspirant
That worked thanks đ I don't trust security software that reports other security software đ§
