KiwiChris
Jan 08, 2022Aspirant
How do I remove a router from Armor?
I have two routers under Netgear Armor and need to remove the nighthawk one as it no longer exists. I have searched without success as to how to do this and cannot contact Netgear support as my produ...
Jan 10, 2022Guru - Experienced User
A factory reset of the router and setup from scratch will also disable Armor.
KiwiChris wrote:
I have two routers under Netgear Armor and need to remove the nighthawk one as it no longer exists. I have searched without success as to how to do this and cannot contact Netgear support as my products have both lapsed. Can anyone help?
