Kellian
Feb 20, 2021Follower
How do I remove a router from my Netgear Armor account?
My Nighthawk X6 AC3200 died and I had to replace it and now I would like to remove it from my Netgear Armor account and can't find a way to do it. Any help would be much appreciated. Thank you in adv...
Christian_R
Feb 23, 2021NETGEAR Employee Retired
Hello Kellian,
Welcome to the community! May you send me a private message with your email address and router serial number.
Thanks,
Christian
Grogie1977
Mar 06, 2021Tutor
I have the same question. I have called bitdefender, but I waiting on a ticket. I tried to activate my Armor for the router using my app but I am receiving an error, unable to activate. On the app I have the correct router showing Netgear Nighthawk AX8 Rax70 6600, but on my Netgear Armor website login it looks like a picture similar to my old router Netgear Nighthawk X8 R8500 that doesn't have Netgear Armor, except it shows 3 antennaes on the picture instead of 4. I believe I may need to delete the one on Netgear Amour webpage to activate my new one. Though on the WebPage their isn't an option to delete the router it is showing.
