ScottBLA
Aug 07, 2019Guide
How do I remove Bitdefender Mobile Security for iOS from my iPhone X
I would like to completely remove Bitdefender Mobile Security from my iPhone X, but can't seem to find any accurate instructions. My subscription to NetGear Armor says that all my device types have 3...
- Aug 08, 2019
Yes, I have Bitdefender for NETGEAR Armor app installed, butif you look under app info, it calls it Bitdefender Mobile Security v1.1.2
DexterJB
Aug 08, 2019NETGEAR Moderator
Hi ScottBLA, Bitdefender Mobile Security is different from the Bitdefender for NETGEAR Armor app. You should have the Bitdefender for NETGEAR Armor app installed instead since that is the one synced up to your Armor subscription. The app is linked below.
https://apps.apple.com/us/app/bitdefender-for-netgear-armor/id1322992373
Dexter
ScottBLA
Aug 08, 2019Guide
