ScottBLA's avatar
Aug 07, 2019
How do I remove Bitdefender Mobile Security for iOS from my iPhone X
I would like to completely remove Bitdefender Mobile Security from my iPhone X, but can't seem to find any accurate instructions. My subscription to NetGear Armor says that all my device types have 3...
  • ScottBLA's avatar
    ScottBLA
    Aug 08, 2019
    Yes, I have Bitdefender for NETGEAR Armor app installed, butif you look under app info, it calls it Bitdefender Mobile Security v1.1.2
