GreenBadger
Mar 18, 2019Follower
How do I remove this garbage from my router?
Updated to the latest Orbi firmware and enabled the trial of armour.
Today the router is blocking my access to legitimate websites falsly claiming they are phishing sites.
I canot see any...
utr9iuy
Apr 04, 2019Tutor
i WANT TO KNOW ALSO ! THIS IS COMPLETE GARBAGE, I AM ON HOLD RIGHT NOW GETTING TERRIBLE SERVICE FROM NETGEAR.
gdsperl
Apr 04, 2019Initiate
Check your router’s app—that’s where it was for me.
- ErnestTheGreatApr 04, 2019NETGEAR Employee Retired
Open up your app go to Settings > Security and toggle the Enable Netgear Armor switch and this will disable it.
- MosenDec 11, 2021Tutor
That would work, if it was there when I needed it. The slider appears and disappears at will! Asked for a refund but cant uninstall it!
