GreenBadger
Mar 18, 2019Follower
How do I remove this garbage from my router?
Updated to the latest Orbi firmware and enabled the trial of armour.
Today the router is blocking my access to legitimate websites falsly claiming they are phishing sites.
I canot see any...
gdsperl
Apr 02, 2019Initiate
I tried it and I agree—there's nothing special here, and it's definitely not worth $70/year (maybe for a non-power user, or a senior citizen, I can see this being useful). So I found this thread as I was trying to turn it off—and I found it.
I can't speak to all of the possibilities, but I couldn't find it anywhere in the web interfaces (and the Armor web interface is complete dung). So, I dug into the app. On the Orbi app for iOS, you can disable Armor by drilling though the settings (presumably the Android app and the Nighthawks have similar settings).
Go to the home icon in the upper left, then tap settings, then tap Security, and there should then be a toggle to Enable NETGEAR Armor. Just turn the toggle off, like so:
Windwalker76
Jan 22, 2021Aspirant
Yeah, I try to toggle it off, and it tries for 60 seconds then gives up.
"Process is taking too long (more than 60 secs), Try again!!"
Gotta love the extra garbage they put on these things just for a desperate upsell...
