GreenBadger
Mar 18, 2019Follower
How do I remove this garbage from my router?
Updated to the latest Orbi firmware and enabled the trial of armour.
Today the router is blocking my access to legitimate websites falsly claiming they are phishing sites.
I canot see any...
Nobodynew
Nov 09, 2021Aspirant
Everyone forgets to tell you that when you unplug the router you need to open the nighthawk app hit the home button and open settings, wait until the WiFi it’s up before the router has established a cloud connection ( the internet ) open the anywhere access and disable it!!!! Only then can you open the security tab and turn the switch off for nether armor, I don’t have time to reset my world personally . Hope this helps next time
