wolfereeno
Jul 21, 2019Apprentice
How do I subscribe to armor/bitdefender?
I activated it via the orbi ios app but might now be past the trial offer. So how do I even purchase this? And do I get it from Netgear, Bitdeffender? When I follow the instructions i find her...
DexterJB
Jul 21, 2019NETGEAR Moderator
Hi wolfereeno, welcome to the community! The links below may help out.
https://kb.netgear.com/000059445/How-do-I-subscribe-to-NETGEAR-Armor-after-my-free-trial-expires
Let me know if you encounter any issues.
Dexter
- wolfereenoJul 22, 2019Apprentice
When I go through KB 1, there are no offers or any way to subscribe.
When I use KB 2, after logging in, i can get to the screen that says my account is active for one device, but there are no offers or ways to get an activation code. And my ORBI app on my iOS continues to say that Armor is Expired.
So no, there's seems to be no way to subscribe.
- DexterJBJul 22, 2019NETGEAR Moderator
Hi wolfereeno, thanks for responding. It is best to reach out to the Bitdefender support team for them to check it on their end. You can reach them on their support channels using the link below.
https://www.bitdefender.com/consumer/support/
Dexter
Ok, I'll do that but isn't Netgear reselling bitdefender? If so, they're not making it easy!
Can I buy Bitdefender directly from them and then just add it to my Orbi?
Hi wolfereeno, subscription will be handled by Bitdefender. Yes, they will be able to assist you in subscribing to Armor. Let us know how that goes.
Dexter
- wolfereenoJul 23, 2019Apprentice
Thanks - is there a preferred version I should get to work with the Orbi? Or do all of them work?
Just curious, does Symantec have an add in for the ORBI? I already have a sub for them.
Thx
