wolfereeno
Jul 21, 2019Apprentice
How do I subscribe to armor/bitdefender?
I activated it via the orbi ios app but might now be past the trial offer. So how do I even purchase this? And do I get it from Netgear, Bitdeffender? When I follow the instructions i find her...
DexterJB
Jul 22, 2019NETGEAR Moderator
Hi wolfereeno, thanks for responding. It is best to reach out to the Bitdefender support team for them to check it on their end. You can reach them on their support channels using the link below.
https://www.bitdefender.com/consumer/support/
Dexter
wolfereeno
Jul 22, 2019Apprentice
Ok, I'll do that but isn't Netgear reselling bitdefender? If so, they're not making it easy!
Can I buy Bitdefender directly from them and then just add it to my Orbi?
