RobiePC
Mar 26, 2020Aspirant
How do I turn NETGEAR Armor off using the Nighthawk app? The toggle does not turn it off.
Turning the toggle for "Enable NETGEAR Armor" in the app (where I initially turned it on) does not work. The toggle is off but the security is still "activiated." It is slowing down my wifi and drops...
Christian_R
Mar 27, 2020NETGEAR Employee Retired
Hello RobiePC,
May you try reinstalling the Nighthawk app and let us know if your issue persists.
Thanks,
Christian
- RobiePCApr 04, 2020Aspirant
Hello NETGEAR community,
I tried reinstalling the Nighthawk app on my iPhone, but Netgear Armor still shows as activated in the app. The “Enable Netgear Armor” toggle continues to be in the off position.
Thanks so much for your help.
Sincerely,
Robie
- Christian_RApr 07, 2020NETGEAR Employee Retired
Hello Robie,
Thanks for getting back. May you provide us a screenshot of the app so we can have a further look. And just to clarify, you've performed the steps in the article linked below to disable Armor.
Thanks,
Christian
- RobiePCApr 08, 2020Aspirant
Hey Christian,
Yes I have gone through the steps in the article you mentioned (netgear.com/000060900/How-do-I-turn-NETGEAR-Armor-on-or-off-using-the-Nighthawk-or-Orbi-app). That article basically just instructs the reader to use the toggle to turn Amor on and off. I did originally use the toggle to turn Armor on, but have been unable to use it to turn it off. The toggle does switch to the off position, but Armor remains "acitivated." I am not sure what page of the app you want to see, but I have attached one of the security page.
Thanks for staying with this!
Take care,
Robie
