GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
DexterJB
Apr 08, 2019NETGEAR Moderator
Hi GLar,
Welcome to the community!
You can disable it the same way you as enabling it. This link may help out. This link from Bitdefender may also help in submitting a safe URL.
Dexter
- JamShadyApr 09, 2019InitiateThat option is not available to me, either on Android, iOS or the web portal. There is no option to turn it off. When you click on security, it just takes you to another screen that shows the router, subscription and selected devices. No toggle to turn it off.
edit: ok, restarting the app forced it to appear, what bad clunky design - guyplaceJun 12, 2019Star
Disable it and you'll discover (like I did) that toggling the on/off switch is useless. Even if you factory reset, Netgear Armour will automatically be reinstalled and activated. Sites continue to be blocked. They got us! What a scummy company!
- JMZZOJun 13, 2019Initiate
Interesting your still having issues when you toggle it off. Once I turned it off using the toggle it solved my upload performance issue and appears it is not blocking any websites. The app icon still shows the subscription as "active" but the service is off. This doesnt really help you, but just letting you know how it behaved for me.
- guyplaceJun 13, 2019Star
Same websites are blocked after togling Netgear Armour to "off" as before when it was "on." Tried to factory reset system to keep Armour from activating. Obvisously, it was designed (like a virus) to protect itself and to reactivate of its own initiative. Netgear has basically hacked and infected its own customers. I'm guessing it will still be there after trial period expires, then one would be expected to pay for "technical support!" That basically makes Armour "ransomware." I would say there is reasonable probability this is not accidental. The router and satelite are now basically "boat anchors." I will never again buy another Netgear product.
- ms1Oct 15, 2019Aspirant
That's not helpful at all. Please share specific instructions how to remove and disable BitDefender.
