GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
ShankarHokie
Apr 14, 2019Apprentice
Perfect!
I was able to do this on my Android based Orbi App as well.
icanhelpppl
May 02, 2019Initiate
For iOS click the cloud in the top left corner then settings then security then you may toggle it off from there!
- RobLWMay 08, 2019Initiate
If you find that restarting your IOS Orbi app isn't showing you the options you expected, follow these steps:
On IOS you now need to
1) Login to Orbi app
2) Tap the Home icon top left corner
3) Tap Settings at the top of the menu
4) Tap Security near bottom of new menu
It'll say it's validating your account, then load a new screen where at the top you can toggle NetGear Armor to it's best position, OFF!
- Orbi-RocMay 10, 2019Luminary
" ... where at the top you can toggle NetGear Armor to it's best position, OFF!"
Why is that RobLW ? Not that I am challenging your position on Armor, far from it. I have only been using it for two days; and so far I have no issues. I am just curious as to how what factors caused you to drop the product.
