GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
guyplace
Jun 12, 2019Star
I've tried everything I could think of. Now hoping software will stop working after trial subscription ends. Very limited internet until then other than direct connections to ISP cable modem. If it presists after that, I'll just buy a new router. Basically, Netgear has infected its own customers with malware.
PoolBall
Jun 13, 2019Guide
Use the Android or IOS app via phone to turn off Armor. Goto Settings, Security. Menu icon is in top corner of app display.
