GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
mbmartin98
Aug 29, 2019Aspirant
How do I turn Armor off?!? After I set it back up, it's literally blocking every website or iOS interaction I am having. I have to use a separate router connection instead of my Orbi. Help!!!
Bluesrock99
Aug 29, 2019Tutor
Do a complete factory reset. It will ask if you want to turn on/add extra protection/bitdefender. Just click no or skip step.
