GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
DexterJB
Apr 08, 2019NETGEAR Moderator
Hi GLar,
Welcome to the community!
You can disable it the same way you as enabling it. This link may help out. This link from Bitdefender may also help in submitting a safe URL.
Dexter
ms1
Oct 15, 2019Aspirant
That's not helpful at all. Please share specific instructions how to remove and disable BitDefender.
