GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
Lumpyuk
Jan 15, 2020Initiate
I am having the same problem
I do not want this awful malfunctioning price of turd blocking sites I know well
its even blocking product descriptions on eBay !
i can't turn it off from the app ..
if I can't turn it off I will get rid of this modem and go back to Apple which worked out if the box with no problems
DexterJB
Jan 15, 2020NETGEAR Moderator
- aknoJan 16, 2020Star
DexterJBIf you know of how to disable this obnoxious, intrusive software, share it with the group instead of it a secret. There are plenty of people that have been hooked into this subscription service that they don't want and want to get out of without purchasing new hardware. This kind of trap-ware is going to convince people to install open source firmware such as DD-WRT or OpenWRT on your hardware.
- DexterJBJan 16, 2020NETGEAR Moderator
- pizza_pabloJan 16, 2020ApprenticeDexterJB
What are our choices, when the switch, in this procedure, fails to go to the OFF position?
