GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
DexterJB
Jan 15, 2020NETGEAR Moderator
akno
Jan 16, 2020Star
DexterJBIf you know of how to disable this obnoxious, intrusive software, share it with the group instead of it a secret. There are plenty of people that have been hooked into this subscription service that they don't want and want to get out of without purchasing new hardware. This kind of trap-ware is going to convince people to install open source firmware such as DD-WRT or OpenWRT on your hardware.
- DexterJBJan 16, 2020NETGEAR Moderator
- pizza_pabloJan 16, 2020ApprenticeDexterJB
What are our choices, when the switch, in this procedure, fails to go to the OFF position? - JimHBFeb 05, 2020Aspirant
Can I disable this trash of a solution from my PC or do I really need to use a phone?
- BAM2019Apr 14, 2020Star
I think you have to use the phone app or contact Netgear support and have them do it for you. The phoen app does anopt always connect well enough to do the disconnect. Really a bad and stupid concept on Netgears app to make this so difficult and not stable! They took a good WiFi system and ruined it with Bitdefender!
