GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
Christian_R
Mar 02, 2020NETGEAR Employee Retired
Hello bsand,
May you provide a screenshot of the error/issue you're experiencing. Specifically when going to Settings > Security and tapping on the toggle to disable Armor.
Thanks,
Christian
pizza_pablo
Mar 02, 2020Apprentice
There is no end to this cycle.
I've cleared app cache, cleared app data, uninstalled app, rebooted and installed app.
Same results.
Same results.
