GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
kellypk65
Apr 09, 2019Initiate
I use the iphone app so here's what i did while in the app:
In the upper left-hand corner there is a icon of a circled house. Click that
Next choose "Settings"
Next choose "Security"
Turn off the "Enable NETGEAR Armour" switch.
hope that helps.
IanB1015
Mar 29, 2020Aspirant
While this is helpful shutting it off, I wish I could exclude IP addresses entirely from the app or from the router GUI. It would make life a whole lot easier because I only want to exclude the one work device.
- pizza_pabloMar 31, 2020ApprenticeIanB1015
How did you get it "shut off"?
