GLar
Apr 08, 2019Follower
How do I turn off Armor/Bitdefender on my Orbi Router
I foolishly accepted trying Netgear's Armor by BitDefender on my Orbi Router mesh and it is now blocking long-used very safe sites that I urgently need for my work, yet there is not obvious way to ei...
Tom4278
May 25, 2020Aspirant
As many others have said, including me, turning off Armor, does NOT remove the website BLOCKING issue. It obviously should, but for some unexplained reason (other than yearly re-occurring revenue to Netgear) they have chosen to force this malware on their unsuspecting customers. As others have said, I also will NEVER be a Netgear customer again‼️
Christian_R
May 29, 2020NETGEAR Employee Retired
Hello Tom4278 & ColoradoBound,
May you confirm that Armor is disabled when looking at the Security Tile of the Nighthawk or Orbi app.
Thanks,
Christian
- StanSpottsAug 28, 2020Aspirant
I hope it's not an indication of lack of support that I can't set my router model from the drop-down for these messages. RAX50 | AX5400 | Nighthawk AX6. And why can't these things have one single model so they're not confusing?
Anyway, same issue as a lot of people are having. Stupidly set the switch in the iOS Nighthawk app to enable Armor, and not cannot disable it. I get the same error message about it taking too long (over 60 secs) and to try again. Reinstalled the app. Nope. Reset the router. Nope. Why woud you let junior programmers operating out of mud huts in the back country in Australia write your code? This is crap. How do I disable this junk? My phones get network access but no internet now, the PS4's lag like hell, the XBox One loses connection several times a day. Only the Windows 10 boxes seem to be stable. All since enabling Armor.
Also, WTF is there something that can only be configured from an app that requires working wifi that is NOT also configurable from the router management page (routerlogin.net) with a wired connection? Someone had a bad case of neural flatulance with that design.
I WANT IT GONE. I DON"T WANT ANY PART OF IT AFFECTING MY NETWORK ANY MORE.- Christian_RSep 03, 2020NETGEAR Employee Retired
Hi StanSpotts,
May you power cycle your router and refer to the article below.
Christian
- dbirdSep 13, 2020Aspirant
Have a RAX45. Having the same issue. When I follow the procedure to turn off the Armor, the app spins for 60 seconds, then times out with no result. Been doing this for an hour, still no joy.
