Spendor
Nov 25, 2024Guide
how to activate armor in RS500?
just bought RS500 and set up as AP, with IOS app, there is no Security option on app which all articles saying that it’s the way to activate Armor. i tried this app on iphone 16 pro max and ipad pro,...
- Nov 25, 2024
If you set up in AP mode, then Armor won't work. Armor requires router mode for it to work.
Nov 25, 2024Guru - Experienced User
- SpendorNov 26, 2024Guide
thanks a lot, btw, when using RS500 as AP, can i use RBS760 — Orbi Tri-Band Mesh WiFi 6 Add-on Satellite as wifi extender for wifi 6 and 5G/2.4G?
