JBukowski
Nov 10, 2019Aspirant
How to I stop the Armour Security Trial
I want to stop the Armor Security Trial that I accepted in error as I have Bitdefender Account already. I am have been extremely frustrated, spending hours to try to fix. Can someone please advise...
JBukowski
Nov 11, 2019Aspirant
Thank you for your prompt reply.
Can you tell me how the browser works. For example if I have my cellphone attached to the Orbi browser network , do I use up my cellphone provider data or does it still pickup on our Rogers provider data?
Orbi-Roc
Nov 11, 2019Luminary
Hi JBukowski .
Airplane mode on your phone turns off; on on most phone, WiFi is still enable; such that you still connect to the internet using your phone's browser and avoid cellular data charges. The same applies when you visit any shop or café that offer free WiFi access. Have a good one.
- Orbi-RocNov 11, 2019Luminary
JBukowski The first part of the first sentence should read "... turns off the cellular and data radio."
Hi JBukowski - Upon reading over your message, I'm not sure if I answered your question fully. If you access the Internet with your phone, you will be using cellular data and be accumulating charges from your cellular service. If you turn on Airplane Mode on your phone, you will be accessing the Internet via your Wifi network instead, in which case data usage will be recorded by your Internet Service Provider.
